Audacity crashes on my Mac as soon as i try to record.
It just freezes or closes.
I’m on 12.2.1 Monterey with high spec Intel Mac
Audacity 3.3.2 for intel
Any thoughts?
Thanks
Any thoughts?
Thanks
Are you recording on a local internal drive (recommended)?
What are you recording?
Did it start misbehaving right after you did the Audacity upgrade?
I re installed old version but still happens so back to new version & still happens
Yes onto local internal solid state drive in Mac
Recording audio from sound card
It sometimes records a little & will play back but then freezes or crashes while playing back.
The error panel thinks you’re on an amd64 processor, not Intel.
Yet I downloaded the intel version ![]()
AMD is based on the x86 architecture. ARM is the M1/M2, as I understand it.
I’m lost
I downloaded the Intel Audacity for my intel Mac, then i get these problems. Don’t know where to go next
