Hi all,
I am getting a
Could not find any audio devices.
You will not be able to play or record audio.Error: Unanticipated host error
error from Audacity, which I am not able to fix for about an hour or so.
Hardware:
Device: Lenovo ThinkPad X1 Carbon Gen 9
Memory: 31.1 GiB
Processor: 11th Gen Intel® Core™ i7-1185G7 @ 3.00GHz × 8
Software:
OS: Arch Linux; Build ID: rolling (64-bit)
Gnome version: 41.3
Windowing System: Wayland
Audacity:
Audacity 3.1.3 (snap)
Program build date: Feb 24 2022
Commit Id: ff6d67 of Wed Dec 22 16:35:36 2021 +0100
Build type: CMake Release build (debug level 1), 64 bits
Compiler: GCC 9.3.0 (Audacity)
I’ve installed and configured ALSA - Advanced Linux Sound Architecture - ArchWiki - support. Sound works great, just not with Audacity. I am running out of ideas and the device log still shows:
Default recording device number: -1
Default playback device number: -1
No devices found
Could someone point me into a direction what I could check?
Thank you for your support.
Rec
