just downloaded fresh install, version 2.1.0 exe
Using Windows 7 Pro
On program start says it can’t load FFmpeg
Under Preferences/Libaries, I direct it to folder “FFmpeg 0.62 for Audacity” folder (which I downloaded from http://lame.buanzo.org/#lamewindl) and to avformat-52.dll.
It doesn’t find it!
I get the Ffmpeg exe and install it (which goes into C:/program files this time.
Still Audacity does not load avformat-52.dll .
The Library reads “FFmpeg library not found” !!!
There is a button to download lame, and FFmeg. Neither does anything!! Luckily it did find Lame
Any answers??
(I need it to import an mp4 video to extract the audio)
Hmmm… I wonder if you have more than one version loaded on your computer… I seem to have a later version “55”.
I found this - C:\Program Files\FFmpeg for Audacity*avformat-55.dll*
If you can’t get it working, try [u]TAudioConverter[/u]. I believe it can extract audio from an A/V file.
[u]SUPER[/u] can also do it, but be careful with that one Their website is tricky so make sure you’re downloading SUPERsetup.exe, and when you install it, be careful about what boxes you check because it might try to install some crapware (or scan your computer afterwards).
