I have absolutely no idea what’s going on and I’m at my wits end. Audacity is now constantly giving me an export error whenever I try to export my project. The catch is literally just yesterday everything was exporting no problem. Now when I try to do it with the exact same export settings in the same destination folder, it’s giving me an error and only exporting the first 17 seconds. I’ve attached pics of what the error looks like. I’ve changed literally nothing so I have no idea why it’s suddenly giving problems
Looks like you might be exporting to an external drive ( USB? ). How big is the file likely to be? Try changing the destination to an internal NTFS drive first. If that doesn’t work try changing the output format to RF64 (RIFF64) which for practical purposes doesn’t restrict output file size. If it is a small file but fails to export to your E: drive try a simpler /shorter destination path to avoid any restrictions such as bad characters or maximum length.
