Version: 2.0.3 (Zip version)
OS: Windows 7 Ultimate x64
Hey guys, i have this problem with Audacity. I recorded it and uploaded it to YouTube. Can you please help me fix it? The audio is not just terrible, it’s extremely slow too!
You need to fill in the holes. How did you shoot it? What’s it supposed to be? If it’s far enough off, we can’t tell what the original show was. Are you trying to record a training video? Koz
That’s not the point, i just shoved that old audio clip in Audacity to show you guys what was happening. It worked fine before. That really distorted sound and slow playback is what i’m getting now when i’m trying to record and edit other stuff.
The first part of troubleshooting problems is to gather as much information as possible about the problem.
So far, all we know is that the audio is terrible and playback is extremely slow.
Sadly that is not enough information to work out the cause of the problem or the solution.
Okay well… My main set up is my ESP LTD EC-100QM → Boss ME-20-> Electro-Harmonix Metal Muff → Vox VT30. If i’m recording something, that’s the stuff i use.
If you’ve not tried already, try rebooting your computer - shut down, switch it off completely then restart it (it’s surprising how often that fixes things).
Assuming that rebooting does not fix it:
If you open Audacity and from the Help menu select “Audio device info”. Wait a few moments for the info to appear, then copy and paste the information into your reply. That’ll tell us a bit about your soundcard.
Also, if you could say what setting you have selected in the device toolbar.
And check in the Transport menu that “Software Playthrough” is off (not selected).
Yeah, i’ve tried rebooting and have turned Software Plathrough off. I cannot remember exactly what settings i had since i played about with them when the problem started to try and fix it myself. Here’s the audio device info:
I doubt that it will make any difference, but it needs to be ruled out. Please disconnect your web cam and reboot again, then see if you can get Audacity to play back correctly. Also, ensure that you don’t have Skype or other conferencing type software running - not even running in the background.
How do you normally play audio files?
If, for example, you play an audio file in Windows Media Player, where does the sound come out (and does it sound normal)?
Actually, it maybe be both then. I don’t know. Even when i add a click track, each beat is distorted and is still extremely slow. I.e, it takes forever for it to get to the first beat even when the tempo is at like a crazy 200 bpm
My guess is that there is a problem with your sound card drivers. It’s a pain if that is the problem, so let’s try something else first.
Reinstall Audacity 2.0.5, and watch for the option to “Reset Preferences”. Select that option when it appears, and complete the installation. When you start Audacity it will ask you to confirm that you want to reset preferences. Confirm that you want to reset preferences.
When you have done that, without changing any settings from the defaults, generate a click track and try playing it. Still the same?
