Audacity appimage keyboard shortcuts randomly stop working on Xubuntu 25.04
I see a similar report in a closed topic with no resolution, but the issue continues here. It’s really frustrating. Closing/reopening Audacity fixes it for a short while, then it stops again.
Yeah, that sounds super annoying. I’ve actually run into something similar on Xubuntu before, it’s like the app suddenly stops listening to keyboard events, and then reopening it magically fixes things for a bit.
From what I’ve seen, this usually happens because of how some desktop environments handle AppImage apps and focus/shortcut grabbing. You might want to try launching Audacity from the terminal with ./Audacity.AppImage --no-sandbox and see if that changes anything. Also, if you’re using any custom global shortcuts or window managers (like tiling ones), they can sometimes interfere. Another trick that helped me once was extracting the AppImage (--appimage-extract) and running it from the extracted folder, it behaves a bit more like a regular app. Hopefully the devs patch this soon, because it’s definitely not just you.
