I am Using Audacity, But It Couldn’t Import Raw Audio Format Unless the Format is “.ul” and “.al”… Please, Fix That By Making the Separate “Import Raw” and “Export Raw” Option.
Ah, I Forgot That, Make Sure You Don’t Forget Those: 8-bit Unsigned PCM, 8-bit Signed PCM, 16-bit Signed PCM, VOX ADPCM, IMA ADPCM, A-law, Mu-law, etc.
