Audacity 4 Alpha on Linux cannot open its own files
Audacity-4.0.0.253031629.f3e3e3b.-x86_64.AppImage
Ubuntu 26.04
This version of Audacity 4 can import and convert aup3 files, but cannot open aup4 files.
New bugs: Audacity 4 complained about two missing libraries, which I installed. Then on the next try I got this before Audacity opened.
/usr/lib/x86_64-linux-gnu/libjack.so.0
/usr/lib/x86_64-linux-gnu/libnss3.so
qt.qml.typeregistration: Invalid QML element name “IconCode”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “MusicalSymbolCodes”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “ContainerType”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “NavigationEvent”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “MUAccessible”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “CompareType”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “SelectionMode”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “ToolBarItemType”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “PopupPosition”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “DockToolBarAlignment”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “Location”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “CloudVisibility”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “SaveToCloudResponse”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “StandardButton”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “TrackType”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “ClipKey”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “ClipStyle”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “AsymmetricStereoHeights”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “ClipBoundaryAction”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “Direction”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “SoloBehavior”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “PlaybackQuality”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “DitherType”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “PlaybackMeterType”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “PlaybackMeterStyle”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “PlaybackMeterPosition”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “PlaybackMeterDbRange”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “SaveLocationType”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “ExportChannels”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “ExportOptionType”; value type names should begin with a lowercase letter
qt.qml.typeregistration: Invalid QML element name “EffectFamily”; value type names should begin with a lowercase letter
15:12:09.828 | INFO | main_thread | GlobalModule::onPreInit | log path: /home/ubuntu/.local/share/Audacity/Audacity4/logs/Audacity_260506_151209.log
15:12:09.828 | INFO | main_thread | GlobalModule::onPreInit | === Started Audacity 4.0.0, build: 253031629 ===
15:12:09.831 | ERROR | main_thread | ConfigReader::read | failed read file: :/configs/languages.cfg, err: [406] An error occurred when reading from the file
15:12:09.858 | INFO | main_thread | LanguagesService::effectiveLanguageCode | System languages: QVariant(QStringList, QList(“C”))
15:12:09.858 | ERROR | main_thread | LanguagesService::setCurrentLanguage | Unsupported language code: “system”
15:12:09.858 | ERROR | main_thread | ConfigReader::read | failed read file: :/configs/ui.cfg, err: [406] An error occurred when reading from the file
15:12:10.098 | INFO | main_thread | DiagnosticsModule::onInit | success start crash handler
15:12:10.112 | WARN | main_thread | Qt | QIODevice::read (QFile, “/home/ubuntu/.local/share/Audacity/Audacity4/midi_mappings.xml”): device not open
15:12:10.112 | INFO | main_thread | AbstractCloudService::readTokens | Could not find the tokens file: /home/ubuntu/.local/share/Audacity/Audacity4/audiocom_cred.dat
15:12:10.112 | ERROR | main_thread | ConfigReader::read | failed read file: :/configs/user_agent.cfg, err: [406] An error occurred when reading from the file
15:12:10.116 | ERROR | main_thread | ExtensionsLoader::manifestPaths | failed scan files, err: [401] The file does not exist
15:12:10.116 | ERROR | main_thread | ExtPluginsLoader::qmlsPaths | failed scan files, err: [401] The file does not exist, path: /tmp/.mount_AudaciJAhBCj/share/audacity4portable-//plugins
15:12:10.116 | ERROR | main_thread | ExtensionsConfiguration::manifestConfigs | failed read config data, err: [406] An error occurred when reading from the file, file: /home/ubuntu/.local/share/Audacity/Audacity4/plugins/plugins.json
15:12:10.135 | ERROR | main_thread | [AU3] Error | libavformat.so.62: cannot open shared object file: No such file or directory
15:12:10.136 | ERROR | main_thread | [AU3] Error | libavformat.so.61: cannot open shared object file: No such file or directory
15:12:10.136 | ERROR | main_thread | [AU3] Error | libavformat.so.60: cannot open shared object file: No such file or directory
15:12:10.137 | ERROR | main_thread | [AU3] Error | libavformat.so.59: cannot open shared object file: No such file or directory
15:12:10.138 | ERROR | main_thread | [AU3] Error | libavformat.so.58: cannot open shared object file: No such file or directory
15:12:10.138 | ERROR | main_thread | [AU3] Error | libavformat.so.57: cannot open shared object file: No such file or directory
15:12:10.139 | ERROR | main_thread | [AU3] Error | libavformat.so.55: cannot open shared object file: No such file or directory
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) [error.pcm] Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) [error.pcm] Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) [error.pcm] Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:886:(find_matching_chmap) [error.pcm] Found no matching channel map
ALSA lib confmisc.c:165:(snd_config_get_card) [error.core] Cannot get card index for -1
Expression ‘stream->capture.pcm’ failed in ‘/home/runner/work/conan-recipes/conan-recipes/.conan_utils/conan/p/b/porta2d9772f4c44b2/b/src/portadio/src/hostapi/alsa/pa_linux_alsa.c’, line: 4626
Expression ‘ret’ failed in ‘/home/runner/work/conan-recipes/conan-recipes/.conan_utils/conan/p/b/porta2d9772f4c44b2/b/src/portadio/src/hostapi/alsa/pa_linux_alsa.c’, line: 1742
Expression ‘AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )’ failed in ‘/home/runner/work/conan-recipes/conan-recipes/.conan_utils/conan/p/b/porta2d9772f4c44b2/b/src/portadio/src/hostapi/alsa/pa_linux_alsa.c’, line: 1909
Expression ‘PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )’ failed in ‘/home/runner/work/conan-recipes/conan-recipes/.conan_utils/conan/p/b/porta2d9772f4c44b2/b/src/portadio/src/hostapi/alsa/pa_linux_alsa.c’, line: 2173
Expression ‘PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )’ failed in ‘/home/runner/work/conan-recipes/conan-recipes/.conan_utils/conan/p/b/porta2d9772f4c44b2/b/src/portadio/src/hostapi/alsa/pa_linux_alsa.c’, line: 2842
ALSA lib pcm_dsnoop.c:572:(snd_pcm_dsnoop_open) [error.pcm] unable to open slave
15:12:32.202 | ERROR | main_thread | [AU3] Error | libavformat.so.62: cannot open shared object file: No such file or directory
15:12:32.202 | ERROR | main_thread | [AU3] Error | libavformat.so.61: cannot open shared object file: No such file or directory
15:12:32.202 | ERROR | main_thread | [AU3] Error | libavformat.so.60: cannot open shared object file: No such file or directory
15:12:32.202 | ERROR | main_thread | [AU3] Error | libavformat.so.59: cannot open shared object file: No such file or directory
15:12:32.202 | ERROR | main_thread | [AU3] Error | libavformat.so.58: cannot open shared object file: No such file or directory
15:12:32.202 | ERROR | main_thread | [AU3] Error | libavformat.so.57: cannot open shared object file: No such file or directory
15:12:32.202 | ERROR | main_thread | [AU3] Error | libavformat.so.55: cannot open shared object file: No such file or directory
15:12:32.203 | ERROR | main_thread | [AU3] Error | libavformat.so.62: cannot open shared object file: No such file or directory
15:12:32.203 | ERROR | main_thread | [AU3] Error | libavformat.so.61: cannot open shared object file: No such file or directory
15:12:32.203 | ERROR | main_thread | [AU3] Error | libavformat.so.60: cannot open shared object file: No such file or directory
15:12:32.203 | ERROR | main_thread | [AU3] Error | libavformat.so.59: cannot open shared object file: No such file or directory
15:12:32.203 | ERROR | main_thread | [AU3] Error | libavformat.so.58: cannot open shared object file: No such file or directory
15:12:32.204 | ERROR | main_thread | [AU3] Error | libavformat.so.57: cannot open shared object file: No such file or directory
15:12:32.204 | ERROR | main_thread | [AU3] Error | libavformat.so.55: cannot open shared object file: No such file or directory
15:12:32.205 | ERROR | main_thread | EffectConfigSettings::Load | failed read file: /home/ubuntu/.config/audacity4/pluginregistry.cfg, err: [406] An error occurred when reading from the file
15:12:32.206 | ERROR | main_thread | EffectConfigSettings::Load | failed read file: /home/ubuntu/.config/audacity4/pluginsettings.cfg, err: [406] An error occurred when reading from the file
15:12:32.235 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: accessibility-dev-show-tree
15:12:32.235 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: multiinstances-dev-show-info
15:12:32.235 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: diagnostics-show
15:12:32.235 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: pinned-head
15:12:32.235 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: undo-history
15:12:32.235 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: mixer-board
15:12:32.235 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: edit-meta-data
15:12:32.235 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: timer-record
15:12:32.235 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: compare-audio
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: drag
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: get-info
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: help
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: import2
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: export2
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: message
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: open-project2
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: save-project2
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: get-preference
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: set-preference
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: select-time
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: select-frequencies
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: select-tracks
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: set-clip
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: set-envelope
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: set-label
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: set-project
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: set-track-status
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: set-track-audio
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: set-track-visuals
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: contrast-analyser
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: sel-prev-clip-boundary-to-cursor
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: sel-cursor-to-next-clip-boundary
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: sel-next-clip
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: curs-prev-clip-boundary
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: curs-next-clip-boundary
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: clip-left
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: clip-right
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: silence
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: trim
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: split-new
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: preferences
15:12:32.236 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: file-save-copy
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: export
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: import-audio
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: import-labels
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: import-raw
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: export-mp3
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: export-wav
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: export-ogg
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: export-f-l-a-c
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: export-sel
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: quick-help
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: manual
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: about
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: edit-labels
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: add-label-playing
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: type-to-create-label
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: prev-frame
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: next-frame
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: prev-track
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: next-track
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: first-track
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: last-track
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: toggle
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: toggle-alt
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: manage-generators
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: manage-effects
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: get-more-effects
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: manage-analyzers
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: manage-tools
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: config-reset
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: simulate-recording-errors
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: detect-upstream-dropouts
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: write-journal
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: select-none
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: sel-sync-lock-tracks
15:12:32.237 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: sel-track-start-to-end
15:12:32.238 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: sel-save
15:12:32.238 | WARN | main_thread | ShortcutsRegister::readShortcut | ignoring shortcut for invalid action: sel-restore
and more, but I cannot post that much here.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
