Audacity 4,01 No metadata sent when exporting aiff
Hello
I just downloaded Audacity 4 (big change as I was running an oooold version - audacity 2 something…).
On my previous version metadata stored was exported OK to itunes but now nothing.
I saw a comment that you have to go back to 3.7.9 (issue with mp3 not aiff) but there the data you enter on the project is not saved to the export window - you have to reenter for every track.
I ended up going back to 3.2.0 (!) and there it seems to work ok
Is there a fix planned for Audacity 4?
Thanks
its the same when exporting mp3
Hi
Yes I saw that too
I’m new to the forum, but have used Audacity for a long time
For my use, Audacity 2.3.3 works better than Audicity 4 (!) but it doesn’t work on MAC IOS 27
Do you know if it’s possible to get help other than in the forum? It doesn’t seem like Audacity people answer…
I’ll raise a new topic as well as Audacity 4 crashes constantly…
Thanks
Stick with whatever version of Audacity works for you. Version 3.7.9 is the latest non-version-4.
You can get it here: Download Older Versions of Audacity
My advice to everyone is to use version 3 for real work, but continue to check in with version 4 as the bugs are worked out and features are added back in. Only change over to version 4 if and when it meets your needs.
Thanks a lot for the advice.
Metadata export doesn’t work on that version either (3.7.9) , but I’ll try again.
Do you know if it’s planned to be fixed in AU4?
I used 3.2.0 where it works, but I have problems with it crashing too - I just sent a corrupted file in for help on that.
Really regretting upgrading to Mac 27!!!
Thanks for your help
Martin
Hmm …
I just tried Export Audio choosing Multiple Files based on Labels for MP3 and AIF. All had Title, Artist, Album and Track Number in the metadata.
I’m on macOS 27.
Hello and thanks for the reply.
As I’m not accustomed to that version I probably did something wrong I’ll download that version again and have another go.
Hello again
I successfully downloaded 3.7.9
I couldn’t get it to work as it should - or at least how it did on 2.3.3, but you are right - metadata is exported,.
I uploaded a file and updated the metadata - for some reason there is a default value for Artist, track name and album name coming from my very first exports years ago. Year is blank and comments field is a set of numbers. This was the same on 2.3.3
I split into 2 separate tracks and named them
To export there is no multiple export function so I used export audio
In the dialogue box I have following settings:
AIFF signed 16bit PCM
Multiple files
Separate by track
Use label / track name
The result is the default metadata, not the values I entered for that file. (I updated artist, album title, year and comments)
The value I entered for year was saved and exported though.
The track title entered for each track in the file was correct (but this is not the metadata value - fortunately).
I saw afterwards it is possible to edit metadata from the export dialogue box and that functioned, but you have to do it for every track which is v cumbersome.
On the previous version I was using, the metadata I entered for the project was carried onto all tracks and into the export.
I just saw your comments about how to log an issue so I will do that for this - unless I am doing something wrong (user error !!)
Thanks v much for your help, much appreciated
Martin
There’s no point in logging a bug for Audacity 3 since it is no longer being developed.
That’s not my experience.
I don’t know why it is not working for you.
Because you’ve upgraded from 2.x to 3.2 to 3.7.9 it might be worthwhile resetting your preferences file.
Quit Audacity
Go to ~/Library/Application Support/audacity/
Rename the “audacity.cfg” file to something like “audacity_old.cfg”
Then start Audacity 3.7.9.
If that doesn’t help and you’ve lost some customizations and you don’t want to re-create them from scratch, you can delete the new “audacity.cfg” file then rename “audacity_old.cfg” to “audacity.cfg”. Do this when Audacity is not running.
One last warning. The structure of the .aup3 file changed several times between 3.0 and 3.7. Projects save with 3.7.9 will not open with older 3.x versions.
