Audacity 4.0 shortcuts problem
It can’t save keyboard shortcuts. In the previous version of Audacity, I was used to using Shift+I for Fade In and Shift+O for Fade Out. When I open the settings, manually assign these shortcuts to the respective effects, and save the settings, they work for a while. However, after I save and close the project and then restart Audacity, the shortcuts are no longer saved, and I have to set them up again.
It’s really frustrating and seems like a bug…
I haven’t had that problem yet, but when I try to edit a shortcut and save it, the program crashes to desktop. Seems to be intermittent. Guess we can expect some bugs for the time being. I was wondering if there’s a place to report bugs or see what bugs are being fixed. Been getting other CTDs for other things as well.
Im having the same issue. I use a lot of costume shortcuts and they work fine for a while and then stop working at all. I have to re-assign the shortcuts all over again. The first 3 or 4 ones I assigned work fine. But the later ones keep deleting for some reason. Its like they have a number of times you can use them and then, stop working. Sometimes they just don’t work and sometimes they are deleted and you have to re-assig them again.
Similar story here. I’ve had my shortcuts not save. I’ve also had the program crash when trying to save them. EXTREMELY frustrating… :face_with_symbols_on_mouth:
On my installation the immediate frustration is that the Home key does not jump me back to the start of the track - always worked on Audacity 3.x
