Audacity 3.7 is playing the recorded sound 2 semitones higher than what I’m playing. The speed multiplier is set to 1X and the percentage change is 0.0 (both default). I don’t know what to do, I never had this problem with older versions of the software! I need someone help, please! PS: I don’t know if it’s important but I’m running it on windows 11!
Did you change your hardware?
Are you using different hardware for recording & playback, such as recording with a USB microphone and playing-back on your regular soundcard?
