I am using v. 3.7.9. I was recording the other day when suddenly there was no wave. It’s a flatline. I tried to uninstall then reinstall, that didn’t work. I’ve just connected Vocaster two -I thought it was my Vocaster One, but everything is connected properly, I double checked the settings and it’s still not working. I’ve had to Normalize, compress, etc. so I can hear the recording and adjust accordingly for auditions.
Thanks for responding. I use a laptop, a mic, Vocaster One, when this happened and audacity. I had done some auditions, everything was fine, and then it wasn’t. Honestly, in a matter of a few hours. I didn’t change anything. To return to my pc to do another audition, I found the wave flat. I went to Audacity 4 and the same thing happened. I reinstalled; it didn’t help. I thought maybe I mistakenly changed a setting but it’s not the case.
In such cases, I usually suspect that you did not grant permission to Audacity for accessing “microphone”. Such permissions are necessary in all recent versions ov macOS and Windows, I am not sure about Linux. Since a “laptop” can have any of these operating systems, you must find out where to look for these permissions. On macOS it is in System settings → Privacy and Security → Microphone.
