I had Audacity 3.7.7 running smoothly under Windows 11, until I installed the OpenVino AI plugin using the Muse Hub App. Now, trying to start Audacity, I get a crash report and won’t open. Trying to send the crash report I get a message that sending failed. The only way to use Audacity is to uninstall the OpenVino AI plugin, but the whole point was to be able to use the plugin. Can anyone shed a light on this issue, please?
I did as you did and encountered the same problem. Can’t even send the crash report and can’t open Audacity to uninstall that Vino plug-in.
I’ve uninstalled Audacity, turned off computer, downloaded Audacity and still the same problem.
Help!
It is a bit of a pain, but you can use the standard Windows uninstall to remove OpenVino and Audacity, restart and only reinstall Audacity. I am not going to try OpenVino again, unless all bugs are fixed.
Thank you. I did as you suggested. I can now access Audacity once more. Much appreciated.
