Audacity 3.7.5 not recording
I’m using a Lenovo computer, running Windows 11 with AMD Ryzen 7 7730U Processor and Raeden Graphics. I’ve used this computer with a Gemini Gemine 4000BT Mixer to record a weekly syndicated radio show for almost 2 years, and recently, moved all of my radio show files to One Drive.
Audacity is no longer recording in either channel. and gives me a dark line on the top channel while recording. I also get a mic image periodically, superimposed on the screen (see screen shot).
Could someone on the Forum please point me to a solution? Thanks very MUCH!
David
Does it start working if you ignore Microsoft One Drive and do the work on your internal drive? Even further, can you disconnect your network and try doing production? Audacity doesn’t much like connecting directly to outside drives.
You can do production on the internal drive, finish, close Audacity, and then shuffle things in and out of One Drive? Move work back to the internal drive and open Audacity. Don’t let Audacity see you trying to work on external, network, internet, or cloud drives directly.
What is your show? Simple interview in your house? Music Production? Monolog? You can have troubles depending on how complicated the show is.
You can have troubles with Audacity 3.7.5, too. I’m bringing a new machine on line and I’m installing Audacity 3.6.2.
Thanks for your Reply, Koz.
The problem with recording began before I moved the files to One Drive. Also, I’ve been on 3.7.5 for at least 3 weeks without issue.
Note the “phantom” microphone image at the bottom of my screen shot. I’ve not seen that before, and didn’t see it listed as issue here in the Forum. Is that a bug?
FYI, the Show is an “oldies” show, variety pop, rock, R&B, cross-over country for low power stations heard across the country through the Audioport network.
CDM-4000BT Dual CD USB DJ Player with Bluetooth Streaming
Cool. So it’s a DJ in a box.
Can I assume you’re connecting to the computer through Bluetooth? So you are trying to manage two different network connections at the same time.
Have you been producing your work on the internal drive up until now?
Não sabia que dava pra gravar podcast, web rádio, programas de streming direto com Audacity, gostaria de saber como fazer isso? Obrigado amigos!!
Yes, I’m producer and voice “talent”, but no Bluetooth involved. I use the Gemini mixer to mix various CD’s, two turntables, and two separate USB ports for importing music. There is Bluetooth access as well which I haven’t used. I’m also only using home WiFi to get to the Internet. After recording and editing, I submit my MP3 files to the Audioport network where stations pick up the two, one-hour Show segments weekly.
And yes, previously I used my saved files from my internal hard drive to produce my Show files.
Follow up to my Reply re: no Bluetooth: I am using a Mixer output into a cable that translates the mixer signal output to a USB input for my computer.
Any other suggestions so I can get back to recording?
You almost told us how you’re getting the music from the Gemini into the computer.
I don’t think that ghost microphone icon is coming from Audacity. I think that’s the computer complaining about a bad connection.
Dueling posts.
What happens if you disconnect the WiFi, pull the interconnect cable—both ends, and do a clean shutdown…
Bring the machine back up, wait for it to settle, connect the cable, and test it.
Have you any other way to produce your show? I’m not an Audacity 3.7.5 user and I’m not on Windows. Note that there are no Windows users racing to help. This is a forum—users helping each other. Not a Corporate Help Desk.
Obrigado amigos!!
You have posted in the middle of someone else’s messages. Repost using a new message and someone will try to help you.
I know you’re waiting for me to tell you which button to push to clear everything up. I’ve never met this problem before.
I would be “backing up” to a known, good, working system so you can continue with your show. Then we can take some time solving the issue. What would you do if the computer never comes back?
I have several different ways to record my voice and post on the forum. I could produce voice work on my phone in the car if I had to. I’m not joshing. I tried it.
Do you have any backup shows in case your production studio fails?
I have had adapter cables fail. Do you have more than one or can get another one?
That’s the same setup that was working before, right?
Make sure you’ve selected the USB device as your Recording Device (Don’t select anything that says “loopback”).
Check your Windows Permissions/Privacy Settings for the USB device to make sure Audacity is allowed to use it.
Try Listen To This Device to make sure Windows is getting a signal from the USB device.
I’m betting significant chocolate that the One-Drive connection is messing things up. That’s why I said to disconnect the WiFi before you shut down and reset everything.
I found a page detailing One-Drive problems.
https://www.pcmag.com/how-to/common-problems-with-microsoft-onedrive-how-to-fix-them#
One of them caught my eye.
  1. Your PC is Running Low on Space
DVDdoug
Thanks for your input. Yes to all the setup suggestions. I read and checked all of these in the Audacity manual before coming on the Forum.
David
Continuing the discussion from Audacity 3.7.5 not recording:
Koz,
Sorry to be slow responding but Sunday is a very busy day with church music and choir rehearsals.
  1. I’m not low on space, quite the contrary as I have 930 GB of space, 849 GB free.
  2. Yes, I tried replacing the “translator” cable with new. I bought two originally knowing my dependency on the connection between the mixer and computer. I started buying a duplicate cable/jack for every “dependent” cable/jack after traveling in a band almost 50 years ago!
  3. Also, and finally, Yes I have about two years of “backup” shows to submit as needed.
  4. Haven’t tried the “reboot” yet, but will give it a go.
Again Many thanks for your helpful questions and directions. Is there not a direct technical support team at Audacity? The Forum is great but I may have a unique issue.
David
