The program says to to file / open but that or import do not work.
How big is your project file? Are you willing to share it to let someone else try ie me?
Mark B
Are you getting any kind of error message?
Open should work if the AUP3 is good but you can’t import an AU3P project.
…AUP3 files are a bit more “fragile” than regular audio files (WAV, MP3, etc.) It’s “good practice” to keep backups and to export as WAV or FLAC whether you’re making a project file or not.
Unfortunitly this was a WAV file output from a board at one of our gigs. The engineer gave us a flash drive from the board. When I checked it, it was an AUP3. I have Audacity but as I stated it will not open. I can’t reach the engineer he is in Florida, and we are back in NJ. Could his version be older and not updated?
It is 1.39 GBs. I can add it to drop box. It is one set of our gig.
This is confusing. How can it be both? Could you clarify, please?
Thanks.
Mark B
I know of two Project formats: The older AUP project Info file with a _DATA folder carrying the sound, and the newer, single AUP3 file.
I agree. I think we can pause right here until you contact the Florida team and find out what’s going on. I super-duper doubt someone recorded a live presentation on Audacity, or, went to the trouble to convert a concert to Audacity format for presentation to you.
I can sense an ordinary mistake and if you resolve it may cure the error you have.
Agreed!
Here’s what I found so far. Whether I try to open or import the file, I get the same message:
“Cannot import AUP3 try File>Open instead”. I tried simply renaming a copy to x.wav and opening or importing gave an ‘Incorrect Filetype’ error. Trying the project tools I got an error saying ‘File not a database’. So, at the risk of stating the obvious, it’s probably NOT an Audacity project file. I got no clues from opening in a hex editor.
I tried!
Mark B
There are darker possibilities, but a production mistake is by far the most likely.
