I’ve been using Audacity 3.7.3 for about a month. I was using previous versions for about 3 years. One day V.3.7.3 just stopped playback, no sound at all through speakers or headphones. Checked all the usual settings, everything was correct. Audio playback works perfectly for all other programs on the computer, but not Audacity. I uninstalled Audacity, then did a complete V.3.7.3 new install. Same problem, no audio output from within the program. I could try going to an earlier version, but apparently projects created V.3.7.3 will not open in earlier versions. I’m stuck. Would appreciate any ideas.
Do you know that the playback volume slider is now “hidden” under the playback meters?
Well crap. I did not know that. User
Thank you! That’s all it was.
