Audacity 3.7.3 crashing on fedora silverblue 42
Installed with flathub flatpak. It opens ok but crashes when I try to load an audio file or when I start recording.
system log (captured with journalctl -f:
May 27 21:43:48 fedora gnome-shell[2992]: JS ERROR: TypeError: this.actor is null
                                          _syncEnabled@resource:///org/gnome/shell/ui/windowManager.js:144:25
                                          onStopped@resource:///org/gnome/shell/ui/windowManager.js:161:35
                                          _makeEaseCallback/<@resource:///org/gnome/shell/ui/environment.js:65:22
                                          _easeActorProperty/<@resource:///org/gnome/shell/ui/environment.js:247:60
                                          _destroyWindowDone@resource:///org/gnome/shell/ui/windowManager.js:1611:21
                                          onStopped@resource:///org/gnome/shell/ui/windowManager.js:1599:39
                                          _easeActor/<@resource:///org/gnome/shell/ui/environment.js:160:64
                                          @resource:///org/gnome/shell/ui/init.js:21:20
May 27 21:44:11 fedora audit[84615]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 pid=84615 comm="audacity.bin" exe="/app/bin/audacity.bin" sig=5 res=1
May 27 21:44:12 fedora kernel: traps: audacity.bin[84615] trap int3 ip:7f8e5b51ba9a sp:7ffe38914190 error:0 in libglib-2.0.so.0.8200.5[6fa9a,7f8e5b4cf000+a5000]
May 27 21:44:12 fedora systemd-coredump[84781]: Process 84615 (audacity.bin) of user 1000 terminated abnormally with signal 5/TRAP, processing...
May 27 21:44:12 fedora audit: BPF prog-id=124 op=LOAD
May 27 21:44:12 fedora audit: BPF prog-id=125 op=LOAD
May 27 21:44:12 fedora audit: BPF prog-id=126 op=LOAD
May 27 21:44:12 fedora systemd[1]: Started systemd-coredump@8-84781-0.service - Process Core Dump (PID 84781/UID 0).
May 27 21:44:12 fedora audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-coredump@8-84781-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 27 21:44:12 fedora systemd-coredump[84782]: [🡕] Process 84615 (audacity.bin) of user 1000 dumped core.
                                                Stack trace of thread 2:
                                                #0  0x00007f8e5b51ba9a n/a (/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8200.5 + 0x6fa9a)
                                                #1  0x00007f8e5b518b94 n/a (/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8200.5 + 0x6cb94)
                                                #2  0x00007f8e5b519888 n/a (/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8200.5 + 0x6d888)
                                                #3  0x00007f8e5d6fbc43 n/a (/usr/lib/x86_64-linux-gnu/libgdk-3.so.0.2417.32 + 0x9cc43)
                                                #4  0x00007f8e5d709df3 n/a (/usr/lib/x86_64-linux-gnu/libgdk-3.so.0.2417.32 + 0xaadf3)
                                                #5  0x00007f8e5cb12676 n/a (/usr/lib/x86_64-linux-gnu/libX11.so.6.4.0 + 0x4e676)
                                                #6  0x00007f8e5cb0eeff n/a (/usr/lib/x86_64-linux-gnu/libX11.so.6.4.0 + 0x4aeff)
                                                #7  0x00007f8e5cb0efbd n/a (/usr/lib/x86_64-linux-gnu/libX11.so.6.4.0 + 0x4afbd)
                                                #8  0x00007f8e5cb0fa82 n/a (/usr/lib/x86_64-linux-gnu/libX11.so.6.4.0 + 0x4ba82)
                                                #9  0x00007f8e5caee646 n/a (/usr/lib/x86_64-linux-gnu/libX11.so.6.4.0 + 0x2a646)
                                                #10 0x00007f8e5ba24d77 n/a (/app/lib/libwx_gtk3u_core-3.2.so.0.3.0 + 0x424d77)
                                                #11 0x000056162120411f n/a (/app/bin/audacity.bin + 0x68a11f)
                                                #12 0x000056162120444d n/a (/app/bin/audacity.bin + 0x68a44d)
                                                #13 0x0000561621209f9d n/a (/app/bin/audacity.bin + 0x68ff9d)
                                                #14 0x00007f8e5c6a6a79 n/a (/app/lib/audacity/lib-project.so + 0x14a79)
                                                #15 0x00007f8e5c4f6cca n/a (/app/lib/audacity/lib-utility.so + 0x5cca)
                                                #16 0x00007f8e5c6a29cd n/a (/app/lib/audacity/lib-project.so + 0x109cd)
                                                #17 0x00007f8e5c4f6cca n/a (/app/lib/audacity/lib-utility.so + 0x5cca)
                                                #18 0x00007f8e5c6a3aaf n/a (/app/lib/audacity/lib-project.so + 0x11aaf)
                                                #19 0x000056162126d05c n/a (/app/bin/audacity.bin + 0x6f305c)
                                                #20 0x00005616211596aa n/a (/app/bin/audacity.bin + 0x5df6aa)
                                                #21 0x000056162115af5b n/a (/app/bin/audacity.bin + 0x5e0f5b)
                                                #22 0x000056162115d081 n/a (/app/bin/audacity.bin + 0x5e3081)
                                                #23 0x00007f8e5c25b75f n/a (/app/lib/libwx_baseu-3.2.so.0.3.0 + 0x25b75f)
                                                #24 0x00007f8e5c25b943 n/a (/app/lib/libwx_baseu-3.2.so.0.3.0 + 0x25b943)
                                                #25 0x00007f8e5c25bfc6 n/a (/app/lib/libwx_baseu-3.2.so.0.3.0 + 0x25bfc6)
                                                #26 0x00007f8e5c25c04f n/a (/app/lib/libwx_baseu-3.2.so.0.3.0 + 0x25c04f)
                                                #27 0x00007f8e5c25c152 n/a (/app/lib/libwx_baseu-3.2.so.0.3.0 + 0x25c152)
                                                #28 0x00007f8e5c25d2f2 n/a (/app/lib/libwx_baseu-3.2.so.0.3.0 + 0x25d2f2)
                                                #29 0x00007f8e5b9ebcc2 n/a (/app/lib/libwx_gtk3u_core-3.2.so.0.3.0 + 0x3ebcc2)
                                                #30 0x00007f8e5d0edfe4 n/a (/usr/lib/x86_64-linux-gnu/libgtk-3.so.0.2417.32 + 0x2edfe4)
                                                #31 0x00007f8e5cdb391a n/a (/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8200.5 + 0x1891a)
                                                #32 0x00007f8e5cdc85c3 n/a (/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8200.5 + 0x2d5c3)
                                                #33 0x00007f8e5cdc98f2 n/a (/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8200.5 + 0x2e8f2)
                                                #34 0x00007f8e5cdcfe01 n/a (/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8200.5 + 0x34e01)
                                                #35 0x00007f8e5cdcfec3 n/a (/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8200.5 + 0x34ec3)
                                                #36 0x00007f8e5d3c884c n/a (/usr/lib/x86_64-linux-gnu/libgtk-3.so.0.2417.32 + 0x5c884c)
                                                #37 0x00007f8e5d269f68 n/a (/usr/lib/x86_64-linux-gnu/libgtk-3.so.0.2417.32 + 0x469f68)
                                                #38 0x00007f8e5d26bd66 n/a (/usr/lib/x86_64-linux-gnu/libgtk-3.so.0.2417.32 + 0x46bd66)
                                                #39 0x00007f8e5d6a4d71 n/a (/usr/lib/x86_64-linux-gnu/libgdk-3.so.0.2417.32 + 0x45d71)
                                                #40 0x00007f8e5d703a4e n/a (/usr/lib/x86_64-linux-gnu/libgdk-3.so.0.2417.32 + 0xa4a4e)
                                                #41 0x00007f8e5b50e0f7 n/a (/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8200.5 + 0x620f7)
                                                #42 0x00007f8e5b510407 n/a (/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8200.5 + 0x64407)
                                                #43 0x00007f8e5b510ef7 n/a (/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8200.5 + 0x64ef7)
                                                #44 0x00007f8e5d26ae55 n/a (/usr/lib/x86_64-linux-gnu/libgtk-3.so.0.2417.32 + 0x46ae55)
                                                #45 0x00007f8e5b9c08e5 n/a (/app/lib/libwx_gtk3u_core-3.2.so.0.3.0 + 0x3c08e5)
                                                #46 0x00007f8e5c103e4a n/a (/app/lib/libwx_baseu-3.2.so.0.3.0 + 0x103e4a)
                                                #47 0x00007f8e5c0c2972 n/a (/app/lib/libwx_baseu-3.2.so.0.3.0 + 0xc2972)
                                                #48 0x00005616211129cd n/a (/app/bin/audacity.bin + 0x5989cd)
                                                #49 0x00007f8e5c15571c n/a (/app/lib/libwx_baseu-3.2.so.0.3.0 + 0x15571c)
                                                #50 0x0000561621055fe8 n/a (/app/bin/audacity.bin + 0x4dbfe8)
                                                #51 0x00007f8e5af3c188 n/a (/usr/lib/x86_64-linux-gnu/libc.so.6 + 0x2a188)
                                                #52 0x00007f8e5af3c24b n/a (/usr/lib/x86_64-linux-gnu/libc.so.6 + 0x2a24b)
                                                #53 0x00005616210e3505 n/a (/app/bin/audacity.bin + 0x569505)
                                                ELF object binary architecture: AMD x86-64
May 27 21:44:12 fedora systemd[1]: systemd-coredump@8-84781-0.service: Deactivated successfully.
May 27 21:44:12 fedora audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-coredump@8-84781-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 27 21:44:12 fedora systemd[1]: systemd-coredump@8-84781-0.service: Consumed 374ms CPU time, 192.1M memory peak.
May 27 21:44:12 fedora systemd[2585]: app-flatpak-org.audacityteam.Audacity-1611464110.scope: Consumed 2.146s CPU time, 61.7M memory peak.
May 27 21:44:12 fedora audit: BPF prog-id=126 op=UNLOAD
May 27 21:44:12 fedora audit: BPF prog-id=125 op=UNLOAD
May 27 21:44:12 fedora audit: BPF prog-id=124 op=UNLOAD
May 27 21:44:20 fedora chrome-calendar-edify.desktop[3273]: [0527/214420.672790:ERROR:third_party/crashpad/crashpad/util/file/file_io_posix.cc:153] open /var/home/gilsoncav/.config/google-chrome/Crash Reports/pending/1330f989-9f2d-4c10-a5d5-47224c125da4.lock: File exists (17)
My audio devices:
Audio:
  Device-1: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 0c:00.1
    chip-ID: 10de:22bb class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Texas Instruments PCM2902 Audio Codec type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.3.3:12
    chip-ID: 08bb:2902 class-ID: 0300
  Device-4: ezcap CAM LINK PRO CH4 type: USB
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 10-3:2
    chip-ID: 32ed:3214 class-ID: 0300 serial: <filter>
  Device-5: ezcap CAM LINK PRO CH1 type: USB
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 4-3:2
    chip-ID: 32ed:3211 class-ID: 0300 serial: <filter>
  Device-6: ezcap CAM LINK PRO CH2 type: USB
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 6-3:2
    chip-ID: 32ed:3212 class-ID: 0300 serial: <filter>
  Device-7: ezcap CAM LINK PRO CH3 type: USB
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 8-3:2
    chip-ID: 32ed:3213 class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k6.14.6-300.fc42.x86_64 running: yes
You could try the Appimage version direct from Audacity to see if that is any better. I am guessing from your name that you are Brazilian. Have you tried a nice free program from there called Ocenaudio? I use that as well as Audacity.
Mark B
