What happened to exporting a clip in mp3? The only available exports are uncompressed only…
Bob
Bob
Make sure your music or timeline is is selected (Double-click inside the timeline).
File > Export Audio > Export to Computer. Pick the MP3 settings. The illustration is the super high quality MP3 that ACX demands for audiobooks.
Where do you lose it?
Go to Edit → Preferences → Modules and make sure mod-mp3 (and everything else) is enabled.
Thanks!!
I got it…
Bob
I don’t have Edit > Preferences. Is that a Windows thing?
Good question! I only have Windows. I also don’t see “Audacity” in the top menu bar. It looks like what I see in the manual.
