Version Ubuntu 18.04.5 LTS
Version Audacity 3.0.4
When I mark the recorded audio signal, I go into effects then Filter curve EQ, Manage, Import, open window then in the EQBackup.xml file, the message appears: “is not a valid presets file”. In version 2.2.1 this did not happen !!
The “EQBackup.xml” file is left over from the old “Equalization” effect. Filter Curve EQ uses a different format for presets.
There’s a tool included called “EQ XML to TXT Converter” (https://manual.audacityteam.org/man/eq_xml_to_txt_converter.html) which can convert the old style preset files into the new format.
