Hi
So I installed 2.4.2 as per the detailed and very helpful instructions here. All working well (apart from the wave colour but I think that is me not understanding it!)
Anyway, I downloaded the files for install, built and installed it but the installation only seems to exist in my Downloads folder? So if I shift that folder anywhere else, Audacity will not load. I thought it would have copied files to the main file location in Linux Mint?
I have probably explained that really poorly, sorry!
Kyle
August 20, 2020, 11:19am
2
If you were following these steps: https://forum.audacityteam.org/t/building-audacity-2-4-2-on-ubuntu-20-04/57719/1
ensure that you’ve done the final step:
sudo make install
That’s the step that copies the newly built Audacity into the system directories and creates an App menu launcher (so that Audacity is available in the main App menu).
If you were following these steps: Building Audacity 2.4.2 on Ubuntu 20.04
sudo make install
Nope, double checked, had done that as it appears in my Main menu to launch.
Just moved the install folder from Downloads to somewhere safe and Audacity doesn’t launch again?
August 20, 2020, 1:18pm
4
Audacity should be installed here:
/usr/local/share/audacity/
No, I just have 6 items in that location. So it looks like everything is just in my Downloads folder - do I need to move that folder into user/local/share/audacity?
August 20, 2020, 1:39pm
6
Do you mean that you have 6 items in
or 6 items in
/usr/local/share/
Sorry, was in wrong folder
August 20, 2020, 4:46pm
8
Which instructions? Please post a link.
August 20, 2020, 9:21pm
10
Those instructions will install Audacity to /usr/local /share/audacity/
Your screenshot shows the installation path for the repository version of Audacity, /usr/share/audacity/
I’m confused, sorry, do I need to redo it all again?
Edit
In both/usr/share/audacity and/usr/local/share/audacity, I see the same three folders and one file?
The only way it seems to exist and run is in my Downloads folder. I’m sorry if I am a bit slow on the uptake
August 21, 2020, 7:29am
12
It will certainly be less confusing if you uninstall the repository version before installing 2.4.2.
I’m so confused? The instructions didn’t say anything about building in a different folder? Legit have I missed something?
August 21, 2020, 10:18am
14
It doesn’t matter much where you build it.
I build in “~/Sourcecode/audacity/”
If it builds correctly without errors, then “sudo make install” command will copy the build to the correct system locations (mostly “/usr/local/share/audacity/”)
Hi
No, same again
sudo make install
[sudo] password for studio:
[ 3%] Built target locale
[ 3%] Built target version
[ 3%] Built target wxregex
[ 7%] Built target wxjpeg
[ 14%] Built target base
[ 16%] Built target net
[ 37%] Built target core
[ 37%] Built target adv
[ 38%] Built target html
[ 38%] Built target xml
[ 38%] Built target qa
[ 39%] Built target lame
[ 45%] Built target libsndfile
[ 45%] Built target libsoxr
[ 46%] Built target portaudio-v19
[ 48%] Built target libid3tag
[ 49%] Built target libmad
[ 62%] Built target libnyquist
[ 62%] Built target suil_x11_in_gtk3
[ 62%] Built target suil_x11_in_gtk2
[ 65%] Built target lv2
[ 66%] Built target portmidi
[ 66%] Built target portmixer
[ 66%] Built target portsmf
[ 67%] Built target sbsms
[ 69%] Built target soundtouch
[ 70%] Built target twolame
[ 74%] Built target nyquist
[ 75%] Built target plug-ins
[100%] Built target Audacity
[100%] Built target mod-script-pipe
Install the project...
-- Install configuration: "Release"
-- Up-to-date: /usr/local/share/man/man1/audacity.1
-- Up-to-date: /usr/local/share/appdata/audacity.appdata.xml
-- Up-to-date: /usr/local/share/icons/hicolor/scalable/apps/audacity.svg
-- Up-to-date: /usr/local/share/icons/hicolor/48x48
-- Up-to-date: /usr/local/share/icons/hicolor/48x48/audacity.png
-- Up-to-date: /usr/local/share/icons/hicolor/24x24
-- Up-to-date: /usr/local/share/icons/hicolor/24x24/audacity.png
-- Up-to-date: /usr/local/share/icons/hicolor/16x16
-- Up-to-date: /usr/local/share/icons/hicolor/16x16/audacity.png
-- Up-to-date: /usr/local/share/icons/hicolor/22x22
-- Up-to-date: /usr/local/share/icons/hicolor/22x22/audacity.png
-- Up-to-date: /usr/local/share/icons/hicolor/32x32
-- Up-to-date: /usr/local/share/icons/hicolor/32x32/audacity.png
-- Up-to-date: /usr/local/share/pixmaps/gnome-mime-application-x-audacity-project.xpm
-- Up-to-date: /usr/local/share/pixmaps/audacity16.xpm
-- Up-to-date: /usr/local/share/pixmaps/audacity32.xpm
-- Up-to-date: /usr/local/share/pixmaps/audacity.xpm
-- Up-to-date: /usr/local/share/locale
-- Up-to-date: /usr/local/share/locale/ca
-- Up-to-date: /usr/local/share/locale/ca/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/ca/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/ja
-- Up-to-date: /usr/local/share/locale/ja/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/ja/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/fa
-- Up-to-date: /usr/local/share/locale/fa/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/fa/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/it
-- Up-to-date: /usr/local/share/locale/it/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/it/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/ca_ES@valencia
-- Up-to-date: /usr/local/share/locale/ca_ES@valencia/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/ca_ES@valencia/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/af
-- Up-to-date: /usr/local/share/locale/af/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/af/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/km
-- Up-to-date: /usr/local/share/locale/km/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/km/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/ar
-- Up-to-date: /usr/local/share/locale/ar/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/ar/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/eu
-- Up-to-date: /usr/local/share/locale/eu/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/eu/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/sk
-- Up-to-date: /usr/local/share/locale/sk/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/sk/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/hr
-- Up-to-date: /usr/local/share/locale/hr/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/hr/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/cy
-- Up-to-date: /usr/local/share/locale/cy/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/cy/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/bg
-- Up-to-date: /usr/local/share/locale/bg/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/bg/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/pt_BR
-- Up-to-date: /usr/local/share/locale/pt_BR/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/pt_BR/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/sr_RS@latin
-- Up-to-date: /usr/local/share/locale/sr_RS@latin/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/sr_RS@latin/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/ta
-- Up-to-date: /usr/local/share/locale/ta/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/ta/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/hy
-- Up-to-date: /usr/local/share/locale/hy/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/hy/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/sv
-- Up-to-date: /usr/local/share/locale/sv/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/sv/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/pt_PT
-- Up-to-date: /usr/local/share/locale/pt_PT/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/pt_PT/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/vi
-- Up-to-date: /usr/local/share/locale/vi/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/vi/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/uk
-- Up-to-date: /usr/local/share/locale/uk/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/uk/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/bn
-- Up-to-date: /usr/local/share/locale/bn/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/bn/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/pl
-- Up-to-date: /usr/local/share/locale/pl/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/pl/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/da
-- Up-to-date: /usr/local/share/locale/da/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/da/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/fi
-- Up-to-date: /usr/local/share/locale/fi/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/fi/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/zh_TW
-- Up-to-date: /usr/local/share/locale/zh_TW/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/zh_TW/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/my
-- Up-to-date: /usr/local/share/locale/my/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/my/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/fr
-- Up-to-date: /usr/local/share/locale/fr/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/fr/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/hi
-- Up-to-date: /usr/local/share/locale/hi/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/hi/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/be
-- Up-to-date: /usr/local/share/locale/be/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/be/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/zh_CN
-- Up-to-date: /usr/local/share/locale/zh_CN/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/zh_CN/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/de
-- Up-to-date: /usr/local/share/locale/de/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/de/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/oc
-- Up-to-date: /usr/local/share/locale/oc/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/oc/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/ru
-- Up-to-date: /usr/local/share/locale/ru/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/ru/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/ga
-- Up-to-date: /usr/local/share/locale/ga/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/ga/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/gl
-- Up-to-date: /usr/local/share/locale/gl/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/gl/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/sr_RS/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/sr_RS/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/ko
-- Up-to-date: /usr/local/share/locale/ko/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/ko/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/nl
-- Up-to-date: /usr/local/share/locale/nl/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/nl/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/nb
-- Up-to-date: /usr/local/share/locale/nb/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/nb/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/hu
-- Up-to-date: /usr/local/share/locale/hu/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/hu/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/tg
-- Up-to-date: /usr/local/share/locale/tg/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/tg/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/es
-- Up-to-date: /usr/local/share/locale/es/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/es/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/mk
-- Up-to-date: /usr/local/share/locale/mk/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/mk/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/cs
-- Up-to-date: /usr/local/share/locale/cs/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/cs/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/lt
-- Up-to-date: /usr/local/share/locale/lt/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/lt/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/el
-- Up-to-date: /usr/local/share/locale/el/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/el/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/tr
-- Up-to-date: /usr/local/share/locale/tr/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/tr/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/id
-- Up-to-date: /usr/local/share/locale/id/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/id/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/ka
-- Up-to-date: /usr/local/share/locale/ka/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/ka/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/sl
-- Up-to-date: /usr/local/share/locale/sl/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/sl/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/he
-- Up-to-date: /usr/local/share/locale/he/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/he/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/eu_ES
-- Up-to-date: /usr/local/share/locale/eu_ES/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/eu_ES/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/ro
-- Up-to-date: /usr/local/share/locale/ro/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/ro/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/locale/bs
-- Up-to-date: /usr/local/share/locale/bs/LC_MESSAGES
-- Up-to-date: /usr/local/share/locale/bs/LC_MESSAGES/audacity.mo
-- Up-to-date: /usr/local/share/audacity//modules
-- Up-to-date: /usr/local/share/audacity//modules/mod-script-pipe.so
-- Up-to-date: /usr/local/share/audacity//nyquist
-- Up-to-date: /usr/local/share/audacity//nyquist/aud-do-support.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/dspprims.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/seqmidi.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/equalizer.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/nyinit-dbg.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/xlinit.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/evalenv.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/seq.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/sal.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/printrec.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/velocity.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/nyinit.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/profile.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/spec-plot.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/sndfnint.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/stk.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/init.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/nyquist-plot.txt
-- Up-to-date: /usr/local/share/audacity//nyquist/envelopes.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/spectral-analysis.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/nyquist.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/fileio.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/seqfnint.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/test.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/sliders.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/xm.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/nyqmisc.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/sal-parse.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/misc.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/system.lsp
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand6.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand11.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand1.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand8.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand7.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand3.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand2.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand9.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mandpluk.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/sinewave.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand10.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/marmstk1.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand4.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand5.raw
-- Up-to-date: /usr/local/share/audacity//nyquist/rawwaves/mand12.raw
-- Up-to-date: /usr/local/share/audacity//plug-ins
-- Up-to-date: /usr/local/share/audacity//plug-ins/SpectralEditMulti.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/SpectralEditShelves.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/vocalrediso.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/highpass.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/vocoder.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/nyquist-plug-in-installer.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/SoundFinder.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/rms.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/sample-data-export.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/limiter.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/beat.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/rhythmtrack.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/SpectralEditParametricEQ.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/crossfadetracks.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/tremolo.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/noisegate.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/StudioFadeOut.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/notch.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/eq-xml-to-txt-converter.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/sample-data-import.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/delay.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/lowpass.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/adjustable-fade.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/rissetdrum.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/crossfadeclips.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/spectral-delete.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/equalabel.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/SilenceMarker.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/clipfix.ny
-- Up-to-date: /usr/local/share/audacity//plug-ins/pluck.ny
-- Up-to-date: /usr/local/bin/audacity
-- Up-to-date: /usr/local/lib/audacity
-- Up-to-date: /usr/local/lib/audacity/suil_x11_in_gtk2.so
-- Up-to-date: /usr/local/lib/audacity/suil_x11_in_gtk3.so
-- Up-to-date: /usr/local/lib/audacity/suil_x11.so
-- Up-to-date: /usr/local/share/applications/audacity.desktop
-- Up-to-date: /usr/local/share/doc/audacity/LICENSE.txt
-- Up-to-date: /usr/local/share/doc/audacity/README.txt
-- Up-to-date: /usr/local/share/mime/packages/audacity.xml
-- Up-to-date: /usr/local/share/audacity/EQDefaultCurves.xml
studio@studio-Centurion-CQ9204:~/Downloads/audacity-minsrc-2.4.2/build$
August 21, 2020, 12:37pm
16
Have you uninstalled the repository version of Audacity?
I thought I had? Let me double check
Yup, had done, totally removed and reinstalled everything again (rebuilt it), same issue. I can work with it in Downloads, I am puzzled why it it’s doing it?
