Audacity 1.3.13-beta & Slackware 13.1 & wxWidgets-2.8.12 OK
Good day,
After hours of banging my head, I was about to ask if any version of Audacity can be compiled on Slackware 13.1, but then, thank the Lord, the solution dawned on me.
For those who’re out of their minds trying to get Audacity 1.3.13-beta & Slackware 13.1 & wxWidgets-2.8.12 to work together, I found that wxWidgets of this version defaults to compile without unicode support (which can be overridden when you ./configure it with --enable-unicode) and I also found that Audacity of this version ./configure’s by default with unicode support.
(However, if you need unicode, which you may for non-US character sets, you would probably want to recompile wxWidgets with unicode turned on.)
Moderator note: Added from duplicate post
Also had to remove ffmpeg import support in order to get Audacity to compile:
./configure --enable-unicode=no --with-ffmpeg=no && make && make install
I had to first install some other stuff, like libmad, libsndfile, and perhaps Ogg Vorbis, but those went without event
Jesse
