[AUD4] Monitor MIDI device while recording
I am on a fast Ryzen 9 with NVIDIA GPU but when I plug in USB Roland ARIA S-1 Tweak synth the display flashes.
Also I need to reboot or at least log out often to recover from issues with these steps.
Login
go to run Audacity-4.0.0.253031629.f3e3e3b.-x86_64.AppImage on Ubuntu Studio 25.10
I need to use headphone out to hear and record otherwise it has issues.
Sometimes I can hear (enable input monitor) the synth then record and export WAV.
Often this sequence results in display flashing as I type in terminal or when Audacity is recording.
After I exit Audacity the flashing continues until I log out or sometimes need to reboot.
OR
I can unplug the USB S-1 synth.
Anyone use this configuration to test Alpha 2 with hardware MIDI / audio S-1 synth ?
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
