AU4 - Unable to export audio by label?
Hey all,
I’m aware we’re in Alpha but I just did a lovely long mix, added all my labels, went to export by label and I can’t see a way to do it and break up the tracks, so it’s just one long mix.
Let me know if I’ve missed something and there is a new way to do that, but wanted to feedback/check.
Thanks
Export Multiple has not yet been implemented:
Presumably it is/will be possible to save from Aup4 (alpha) into Aud3?
I have a feeling you can’t open an Audacity 4 project in Audacity 3. Someone else might have a definitive answer.
What I meant was, you should have the option to “Save as” an aup3 project from within an aup4.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
