AU Matrix Reverb Problem...
I’m trying to use the AUMatrixReverb effect on audacity 1.3.12., but the delay is so strong that it sounds as if two different tracks are playing. I tried messing with the settings of Matrix Reverb, but nothing seems to make the delay go away. Does anyone know how to stop the delay from being so drastic? Thank you.
The AUMatrixReverb is an Apple-supplied Audio Unit effect, so it is not strictly an Audacity effect.
Have you tried the presets? I’ve found that most of them are quite good. But you need to adjust the dry/wet mix otherwise you get the reverb only, which may be what you are experiencing.
Also see this page on the Audacity wiki for tips on using reverbs: http://wiki.audacityteam.org/index.php?title=GVerb#Duplicate_and_mix_together
– Bill
Ah, I see! Thanks for your help Bill.
