I am working on a presentation and would like to attach Audacity audio to a picture or an object in my documents file. How do I do this?
Audacity creates “Audacity projects”, which are a format that is only understood by Audacity.
To create a normal audio file you must “Export Audio” (in the “File” menu).
Export the audio in a format that is supported by your presentation software, then refer to the manual for your presentation software to find out how to insert the audio. Please note that we are only able to offer technical support for Audacity and not for other software.
