I can hear what you mean.
Are you sure that you are set up to record from the AT2020 and not from a built in microphone on your laptop, or from an attached webcam?
(If you gently run a fingernail across the wire mesh grill on the microphone it should be recorded as a loud scratching sound)
Sorry for the very late reply.
Ah! I see! Maybe that’s my problem. I tried to run my fingernails across the wire, it does recorded as a loud scratching noise. Now the sound is very clear like I want to. Thank you for helping! I really appreciate it!
