Arrow keys are not moving cursor
I just updated to 3.7.3 from version 2 and the arrow keys are not moving the cursor during playback. It worked in the older version. Is this something I need to go into Settings and correct?
In Audacity 3.7.3 arrow keys intentionally don’t move the cursor during playback by default. You can enable the cursor movement in keyboard preferences (edit - preferences - keyboard):
‘Move cursor when playing’ - for left/right arrows
‘Move selection with playback’ - optional, for up/down arrows
Click ok and restart playback to test.
Hi, thanks for the reply. I’m not seeing ‘keyboard’ under edit>preferences. This is the menu I have:
It has been renamed “Shortcuts”.
Found it, thanks!
