I have live band recordings from the inbuilt mic in a SONY ZV E-10 camera
Don’t know how to apply EQ to improve the sound quality (lots of crowd noise)
Hoping for tips / guidance / help, thanks in advance (& apology if this is not the right forum)
You’ll just have to play-around with the Graphic EQ.
There’s not a lot you can do about crowd noise (except between songs when there’s no music). …Noise reduction only works when there’s a small-constant background noise.
You also can’t fix clipping (overload distortion) or excessive reverb.
Thanks. I’m new at this, and am wondering if there’s an “ideal” EQ curve I could apply that will compliment the music but reduce the crowd noise?
Not usually. Both cover most of the audible range.
