AppImage
Hi all,
A quick question and apologies if posted in the wrong section.
I have downloaded Audacity-3.1.3 (AppImage) and it’s working perfectly under Debian 10(64 bit).
The question I have is, where are the different folders created?
By that I mean for example, the plugins folder.
I have quite a few custom .ny plugins and others from this forum which I would like to add.
I could use the Nyquist plugin installer but that would take ages as have to do them one for one.
TIA.
By default they are in multiple locations - I’ve not found all of them.
What I prefer to do is to run the AppImage with a “local home”.
The “local home” folder is in the same directory as the AppImage.
If you launch the AppImage with the “-h” option, it tells you how to create a “local home” folder.
Once you have a local home folder, you should see a plug-ins folder in:
...AppImage.home/.local/share/audacity/Plug-Ins/
Just a thought Paul; do you use mod-script-pipe?
If so, it doesn’t work by default with the AppImage version, but there is a workaround. Basically you have to extract the AppImage somewhere, then mod-script-pipe works. If you need this, start another topic and I’ll look up the exact commands that you will need.
The XDG paths Audacity is using are shown in the About dialog in the build tab.
The user plug-ins folder can be found by running this Nyquist snippet (run it in the Nyquist Prompt):
(get '*system-dir* 'user-plug-in)
Thanks guys, loads of info there.
I did try extract all of the appimage contents (easy to do) but then no matter what I do, it never gets the required permissions to run.
Going to try the options you highlighted.
Thanks guys, it’s solved.
Trying Steve’s Nyquist prompt code returned:
/home/Your_User_Name/.audacity-data/Plug-Ins
This was confirmed with what @LWinterberg suggested by checking the “about” dialog.
Something interesting about that folder though, it was completely empty.
At first I thought it was the wrong place as Audacity does ship with some .ny plugins,
so there should be some in there.
This is what prompted me to post here asking for help.
However, it turns out that since an AppImage is a type of SquahedFS which gets inflated when run,
it creates a mount in tmp.
In my case it was:
/tmp/.mount_audaciB1UlaI/share/audacity/plug-ins/
It does change every time it’s run.
In there then, are the .ny plugins that originally ship with Audacity.
To add new ones, there are two ways:
  1. Use the Nyquist Plugin Installer (It does support multiple files at once).
  2. Copy any new .ny plugins directly to:
(For those that don’t know, with either way, you will still need to enable all the new plugins)
Paul2, Steve, LWinterberg,
Thank you for shining the light on Audacity AppImage Directories.
I have ~two further questions below.
Quick Background:
My ASUS chromebook uses Linux 6.6.46-04024-g9e7e147b4900 x86_64 and it is mostly, or almost in my case, compatible with with Ubuntu 22.04.
I have recently installed Adaucity AppImage version 3.7.0 and I have also
recently installed audcaity-openvino-models for this version 3.7.0 to enable AI Effects in Audacity.
Questions:
  1. Under preferences/ Modules in the Audacity UI, I was able to enable mod-openvino. Also I was able to create ~80 audacity-openvino models (.bin; .xml, .raw files) in /usr/local/lib/openvino-models directory (and sub-directories) shown below. With this I expected them to show up in the Audacity 3.7.0 UI as audacity-openvibo Effects. But they did not show up at all.
I think the audcaity-openvino build instructions were for an Audacity APT deb package build that populate in a different Audacity directory structure. We are still waiting for a stable release of an Audacity 3.7.0 APT deb package.
Where should I port the above mentioned ~80 files into appropriate Audacity AppImage directories that will enable menu options under Generate, Effect, Analyze, and Tools in the Audacity UI with any required sub-menus?
home@penguin:/usr/local/lib/openvino-models$ tree -d
├── deepfilternet2
├── deepfilternet3
├── deepfilternet-openvino
└── musicgen
├── mono
└── stereo
  1. I am unable to set “NEW”, in the “mod-script-pipe” option in preferences/ Modules in the Audacity UI. Is there a directory or a config file that can help me to light up the “NEW” option in these Audacity AppImage directories? Will this above “NEW” option help me process the ~80 models in my Question-1 above? Or do I need to work towards populating them into /tmp/.mount_audaci* directory during a runtime (how?)?
