Windows 11 25H2 - OS Build 26200.7171
I installed Audacity 4 Alpha 2 for Windows (64 bit zip file) succesfully but all I get is the splash screen for a few seconds. The app never starts.
Same results if I start the app as Administrator
Make sure another (headless) copy of Audacity is not already running. The easiest way to ensure that would be to reboot the computer.
Thanks for your reply, Wrecks0.
I have tried rebooting (multiple times).
I have also tried using Task Manager and Ending Task for Audacity. I also tried uninstalling and reinstalling
Same Problem ![]()
Windows 11 Pro | Version - 25H2 | OS build - 26200.7171
Experience Pack - Windows Feature Experience Pack 1000.26100.265.0
Windows version missing FFMPEG files from installer and it won’t start without them. And it seem to use some special own version of FFMPEG and there seem no Windows version at the moment.
FFmpeg For Audacity is installed.
wxDynamicLibrary::Load | Failed to load shared library 'avformat-62.dll'
wxDynamicLibrary::Load | Failed to load shared library 'avformat-61.dll'
wxDynamicLibrary::Load | Failed to load shared library 'avformat-60.dll'
wxDynamicLibrary::Load | Failed to load shared library 'avformat-59.dll'
wxDynamicLibrary::Load | Failed to load shared library 'avformat-58.dll'
wxDynamicLibrary::Load | Failed to load shared library 'avformat-57.dll'
wxDynamicLibrary::Load | Failed to load shared library 'avformat-55.dll'
I tried something different.
I downloaded FFMPEG for Audacity and installed it
Uninstalled Audacity 4 alpha
Deleted all files/folders with anything Audacity 4
Edited the Registry and removed anything Audacity 4 related. There were a few entries that could not be deleted. I ignored those.
Rebooted
Downloaded a fresh copy of the alpha zip file and reinstalled the program
Now it works!!
Does not work for me. I think after uninstalling Audacity 3.7 the Audacity 4.0 stopped launching. Maybe also some windows update to blame. When I double click it, the cursor changes to hourglass for a moment and reverts back to normal.
No splash screen, no nothing.
Tried:
- computer reboot
- uninstall / reinstall
- uninstall / remove (most) registry entries related to audacity / delete all audacity folders / install / launch
My question is: how can I try to debug it? Where shall I look for logs related to app launch?
Identified the error from windows event viewer. The faulting dll is: ucrtbase.dll
Nazwa aplikacji powodującej błąd: Audacity4.exe, wersja: 4.0.0.0, sygnatura czasowa: 0x6a984776
Nazwa modułu powodującego błąd: ucrtbase.dll, wersja: 10.0.26100.9444, sygnatura czasowa: 0x2bbefd73
Kod wyjątku: 0xc0000409
Przesunięcie błędu: 0x0000000000011858
Identyfikator procesu błędu: 0xF48
Czas uruchomienia aplikacji powodującej błąd: 0x1DD47475FCC5FB0
Faulting ścieżka aplikacji: C:\Program Files\Audacity 4\bin\Audacity4.exe
Faulting ścieżka modułu: C:\WINDOWS\System32\ucrtbase.dll
Report Id: 5c4c49d4-fcee-4c21-959b-6cb952717f85
Faulting pełna nazwa pakietu:
Faulting identyfikator aplikacji względnej dla pakietu:
