While I haven’t edited any multi-channel, multi-hour podcasts, Audacity 3.6.1 seems to be reasonably stable. Audacity 3.7.x is the magic one. That’s when they stopped admitting earlier machines exist.
3.6.1 violates a fuzzy numbering rule. Never install X.0 anything. That’s the experimental version they shoved out there to see if it catches fire. X.1 is where they got it to mostly stop catching fire. X.2 is usually the first ready-for-production version.
That’s why 2.4.2 is held in such high regard. It was, as much as possible, unconditionally stable.
Do all your production on the internal drive. Full stop. Audacity does not get along with external, network, or on-line drives. You can close Audacity and move files around wherever you want. Just make sure everything is on the internal drive, and there is room, when you start work.
Someone will say that the newer Audacity versions will recognize and use external drives. Ummmmm. No. The newer Audacity versions have special application and production software that under certain conditions will recognize a special external drive. It’s not a license to go nuts.
This is where early machines with full or small drives run into the people wanting to produce the six hour stereo podcast. Remember, Audacity makes a copy of the whole show when you make an edit. That’s how it produces UNDO.
So do be careful with your older machines.
There are tricks. You can go down through your machine and clear the memories.
My Firefox browser was almost unuseable. I opened History and cleared out thousands of tons of links, notes, and file references. Boom. New Firefox.
Another example. Preview > File > Open Recent > Clear Menu.
I made a list of places to do that. I have it here somewhere…
You can get applications to clear all that out for you, but I’d rather get fresh Starbucks and do it manually.
