I need to boost the volume of the tail of a fade out section. Rather than use the amplify tool to gradually amplify small sections of it, I tried using the Envelope tool for the task.
But if I drag an inner control point to the outer border, the amplification is insufficient, even when zoomed out. If I drag an inner control point beyond the outer margin of the track, it gets lost; and the amplitude of the waveform remains unchanged. Is there a way to additionally increase the amplitude of the waveform with the Envelope tool, so that the peaks of the waveform are closer to the maximum level?
Thanks for the suggestion. I did not find the Adjustable Fade friendly for the task. But I managed to reduce the fade-out rate of a tapered section of the waveform: I zoomed out to double the vertical height, used the Envelope tool to amplify as much as permitted then used the Amplify tool, working in sections, editing along the x-axis to avoid creating artifact.
