Another “Audacity failed to read from a file in C:”
This is the third chapter in a row, chapters 13, 14 and now 15. I EEKED through the previous two fiascos but this one is coming up nothing. When chapter 13 corrupted, I was able to reaccess it by redownloading via sharing to google. Chapter 14, same situation, but only about 80% was recovered and I had to redo the rest. It was at this point that I realized I was an idiot and had been misreading my available disc space (just don’t ask) and purchased an external. I now have almost 100 gigs available on my SSD. This time however, NOTHING is working. Wont open at all, and no, the audacity project tools approach didn’t work on any of these instances. I did save the corruption log this last time if that is helpful at all, though I believe this is happening due to a cloud sync issue. If this can be recovered, I would greatly appreciate any help.
HP Pavilion 16 inch Laptop PC 16-af0000
Device name M_R_Fahrenheit
Processor Intel(R) Core™ 7 150U (1.80 GHz)
Installed RAM 32.0 GB (31.7 GB usable)
Device ID C448A0C9-65CC-44B9-A1A0-082CBDB91ADE
Product ID 00342-21231-67869-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch Touch support with 10 touch points
Edition Windows 11 Home
Version 25H2
Installed on ‎1/‎2/‎2025
OS build 26200.7623
Experience Windows Feature Experience Pack 1000.26100.275.0
TH CH 15 CANT CATCH A BREAK P&R (NO CHIPMONKS).zip
The spate of recent similar problems leads me to the same conclusion. It doesn’t help that Microsoft makes it difficult to NOT save to OneDrive automatically. I did post elsewhere on how to disable or remove OneDrive. I just don’t do Windows any more.
I had a go at this using a combination of tools and I did manage to recover something. I cannot guarantee it’s what you want. I used Audacity 3.7.7 to re-save it. You may need the same version to open it again.
Please send me a PM with your email address and I will send you the project file using Swisstransfer.com.
I hope it’s OK for you.
Thank you so much for looking at it. Hopefully it’s what usable! My email is (REDACTED) in your DMs.
I’d rather not publish my email address here, but send it to evilmrb by personal message.
To do this, click on his username (or on the image next to it) and use the blue “Message”-button.
And delete your post containing your email address.
@M.R.Fahrenheit please review this recovered project: https://drive.google.com/file/d/1kQ4dCb0PsVpPdrQBGXZ1OeMSSvl6pLSF/view?usp=sharing. Does it look good? How much data was lost?
I’m testing the recovery tool we want to include in the next Audacity release. Your feedback is welcome!
So unfortunately, somehow it scrambled the audio and was repeating one line throughout while what should have been playing wasn’t. This is a sample of what it should sound like, brought to you by evilmrb. He was somehow able to magically revive, extract, summon insert your chosen verb here, the original audio despite the methodical madness known as “produced by M. R. Fahrenheit”. I thought knowing what should be playing may be helpful for development. Please let me know if I can offer further testing insight.
What TH CH 15 should sound like (Dev feedback).mp3
Thanks for reply, please try this one: https://drive.google.com/file/d/1n1XncmpeC4KUt_t5VN7fUyLqe2jLpvVV/view?usp=sharing
I assume it should be more or less the same as the project that was recovered by @evilmrb
unfortunately, it was not. I was actually mostly blank clips. Back to the drawing board?
