Annoying Pop sound between 2 tracks
Aud. 2.3.2
I’m getting an annoying click/pop sound when I join 2 split clips on a track. The black line that divides/joins them is where I keep hearing it. I don’t recall it doing that before. How to get rid of that?
A [u]crossfade[/u] will probably fix it, no matter what the cause. The crossfade can be very short (several milliseconds) if you don’t what to hear it as a crossfade.
It could be caused by a [u]DC offset[/u] (usually the result of a hardware problem) or it could be from not cutting on a [u]zero crossing[/u].
