an alternet software besides audacity
hi
i used soundsoap by bias and now they went belly up so i need a software to cleanup 78sbesides audacity what other software can you recommend to me?
lenny
Waxcylinder is rather keen on Brian Davies restoration software … https://forum.audacityteam.org/t/click-pop-removal-clickrepair-software/1933/1
I’ve not tried the Brian Davies software but I have tried Goldwave whose noise reduction is better than Audacity IMO.
I believe both Brian Davies and Goldwave have free trials, so you can try before you buy.
[ You may still be able to use soundsoap if you have the authorization code … http://www.bias-inc.com/ ]
hi i have brian davies click repaire and goldwave too…davies noise reduction id pretty complicated…thanks anyway
lenny
Waxcylinder has posted his settings for Brian Davies software … https://forum.audacityteam.org/t/click-pop-removal-clickrepair-software/1933/1
