I must be missing something or doing something wrong. I’m unable to change the project sample rate to 17500 - or anything else - when I choose " other" in the new "audio settings " window in the new audio set up box . I am able to change the default sample rate but not the project sample rate . does anyone know what I haven’t done correctly that would prevent me from being able to change it. I suspect it might be that I didn’t save the project correctly last time I closed it. I didn’t save it as an Audacity project by exporting it. ???
I can reproduce this, it’s a bug. I’ve raised an issue here:
@LWinterberg - that’s it exactly; it stays greyed out. thank you for letting me know it’s a bug .
As a workaround, you can go to View > Extra Menu and then Extra > Scriptables I > Set Project. In there, you can set the project sample rate then if the checkbox next to it is enabled (as shown in the screenshot.
The bug is fixed now and is going to come with the next patch release, probably today or tomorrow.
