I downloaded audacity recently, so am thinking my version of audacity is latest one. I recorded an audio using Audacity, increased its volume (amplified effects). When I am sending this audio as attachment to my friends to test, then people with older iPhones are able to hear the increased volume in mp3 file, but people on iPhone 14 and higher are not hearing my voice in the mp3 at all. It sounds like an insect buzzing.
With audacity, I imported the original recorded audio, then did a select all, then effects>volume and compress>amplify.
Here I kept the settings which audacity showed, and did APPLY.
Within audacity, the volume increased. Playing in VLC etc also the volume increased.
But playing on iphone 14+, the volume is not audible at all.
I tried increasing the volume using ffmpeg then. Increased volume 10 times. Still same result. No voice audio audible in the file. If I add a background music to the audio using ffmpeg, then people on iPhone 14 and higher are only hearing the music, not my voice. What is happening here?
Why is the music audio playing fine, but the recorded audio is not?
I asked this same question on SuperUser forums, one guy uploaded the fixed AIFF file but he is not answering how he fixed the audio. He has even deleted the audio which he had sent me to test. It played fine on iphone 14 also, and on older iphones also.
Here’s the original input file as recorded by audacity:
tbrjar (dot) com (slash) audio_test (slash) input.mp3
And here is the fixed file which the person from SuperUser forums uploaded, which he deleted later:
tbrjar (dot) com (slash) audio_test (slash) hydranix_AIFF_input.aiff
Below is the ffmpeg command I am using to increase the volume, and its output:
ffmpeg -ss 00:00:00 -i input.mp3 -to 00:00:05 -filter:a “volume=10” -c:a libmp3lame z1.mp3
ffmpeg version 2024-03-04-git-e30369bc1c-full_build-www.gyan.dev Copyright (c) 2000-2024 the FFmpeg developers
built with gcc 13.2.0 (Rev5, Built by MSYS2 project)
configuration: --enable-gpl --enable-version3 --enable-static --pkg-config=pkg
conf --disable-w32threads --disable-autodetect --enable-fontconfig --enable-icon
v --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --e
nable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh -
-enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sd
l2 --enable-libaribb24 --enable-libaribcaption --enable-libdav1d --enable-libdav
s2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --en
able-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvi
d --enable-libaom --enable-libjxl --enable-libopenjpeg --enable-libvpx --enable-
mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-li
bfribidi --enable-libharfbuzz --enable-liblensfun --enable-libvidstab --enable-l
ibvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-
ffnvcodec --enable-nvdec --enable-nvenc --enable-dxva2 --enable-d3d11va --enable
-libvpl --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl
–enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enabl
e-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --e
nable-libtwolame --enable-libvo-amrwbenc --enable-libcodec2 --enable-libilbc --e
nable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --ena
ble-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmys
ofa --enable-librubberband --enable-libsoxr --enable-chromaprint
libavutil 58. 40.100 / 58. 40.100
libavcodec 60. 41.100 / 60. 41.100
libavformat 60. 23.100 / 60. 23.100
libavdevice 60. 4.100 / 60. 4.100
libavfilter 9. 17.100 / 9. 17.100
libswscale 7. 6.100 / 7. 6.100
libswresample 4. 14.100 / 4. 14.100
libpostproc 57. 4.100 / 57. 4.100
Input #0, mp3, from ‘luck1.mp3’:
Duration: 00:00:54.02, start: 0.025057, bitrate: 133 kb/s
Stream #0:0: Audio: mp3 (mp3float), 44100 Hz, stereo, fltp, 133 kb/s
Metadata:
encoder : LAME3.100
Stream mapping:
Stream #0:0 → #0:0 (mp3 (mp3float) → mp3 (libmp3lame))
Press [q] to stop, [?] for help
Output #0, mp3, to ‘z1.mp3’:
Metadata:
TSSE : Lavf60.23.100
Stream #0:0: Audio: mp3, 44100 Hz, stereo, fltp
Metadata:
encoder : Lavc60.41.100 libmp3lame
[out#0/mp3 @ 00000000001a7340] video:0KiB audio:79KiB subtitle:0KiB other stream
s:0KiB global headers:0KiB muxing overhead: 0.313639%
size= 79KiB time=00:00:05.00 bitrate= 129.5kbits/s speed=18.2x
