Pressing Alt + C in Audacity 3.x was the shortcut for the Effects pull-down menu.
It looks like this has not been setup correctly in 4.0, the shortcut for Effects is now letter E but this is already used by Edit menu - so Alt + E is not usable for Effects and currently no shortcut for Effects menu.
Hi @FrillyBits
Thanks a lot for reporting this, and sorry it’s getting in the way of your work.
We’ve identified the issues with the menu bar and shortcuts in Audacity.
Before we can fix them properly, we first need to rework how shortcuts work under the hood (tracked here, planned for 4.1), so these fixes will come after that. I can’t give you a date yet, but your report is part of what we’ll look at.
Thanks!
