Yesterday I edited a song and saved it properly as .aup. Today I reopened it to continue, but all tracks are silent! The weird thing is, that all track parts are exactly in the same place as before, the textmarks are still all there; it’s only that everywhere, where there was sound, now there is just a blue line.
When clicking on play there is as well no sound.
I am relly frustrated and have no clue, why this could happen. I would be very happy if it was possible to fix this
Thanks in advance for any help
OS: Windows 7 HP, 64bit, SP1
Audacity: 2.1.3 (installed via exe)
You saved an Audacity Project whose lead manager file is an AUP. You also need the rest of the Project which is a _DATA folder of the same name. Can you find that _DATA folder?
If there is missing audio data, Audacity will warn about it, and one of the (non-default) options offered, is to “Replace missing audio with silence (permanent immmediately)”.
If you select that option, then the missing audio is replaced by silence, immediately and permanently. Opening that project again in the future will not give an error, but will open with silence in the places that audio data was previously missing.
