Aligning tracks from the end
Hello,
I have lots of clips with a few seconds of noisy sound in the end. I’d like to remove it, is it possible to align the tracks from behind? Couldn’t find a way for it except manually doing it. I have hundreds of clips, so manual work isn’t feasible :stuck_out_tongue:
Thank you in advance!
  1. Ctrl + A (select all)
  2. Effect menu > Reverse
  3. Tracks menu > Align Tracks > Align Together
  4. Ctrl + A (select all)
  5. Tracks menu > Align Tracks > Start to Zero
  6. Ctrl+A
  7. Effect menu > Reverse
Rather than doing all of these commands one at a time, you could make them into a Macro (see: https://manual.audacityteam.org/man/macros.html)
Awesome! A HUGE thank you!
