Hello everyone!
As I’m still learning the Audacity tools, I have some files with characteristics that need adjustments. The attached file is an image of recorded audio only instrumental with keyboard, drums, electric bass and strings. Well after recording I realized that the drums, especially the snare, were very evident with a volume above the other instruments. I would like to learn if there is a possibility or tool in Audacity so that I can attenuate the battery especially the snare. According to the image I imagine that a cut in the peaks where the battery box is presented and highlighted would be necessary.
Would my intention be possible for this to work using Audacity?
Thanks a lot for the help!
