Adding stretching clips keyboard shortcuts
Hello.
I know, that lenght of clip can be set by using ctrl+shift+p dialogue as well as pitch. Or, We can call It speed of a clip. This isn’t problem, but as well as is for changing pitch keyboard shortcuts alt+up/down arrows, It’ll be good if will be alt+left/right arrow to change lenght of a clip. It can be maybe bad idea, but It’ll be good for those, who don’t use mouse (for example blind users of Audacity).
Thank You.
Marco Oros
Audacity doesn’t currently support keyboard shortcuts for stretching clips directly with Alt+Left/Right arrows. You can adjust clip length using Ctrl+Shift+P or use the “Change Speed” effect for more control. Consider suggesting this feature to Audacity’s development team for future updates.
Thank You for Your respond, but this link is strange, which You’ve sent to this topic. Where to find developer’s section on this forum?
Please, how to suggest one feature to development team of Audacity?
