Adding a switchable feature to ensure against loss
Feature Request: Optional Project Preservation Prompt When Opening Existing Projects
Problem
Many Audacity users periodically revisit older recordings to remix, remaster, or substantially rework them.
When opening an existing .aup3 project, it is easy to begin editing and instinctively press Save, unintentionally overwriting the original project.
This is particularly problematic for musicians maintaining archives of recordings accumulated over many years or decades.
Although Save Project As provides a way to preserve the original, it depends entirely on the user remembering to use it before saving changes.
Even experienced users with established naming conventions occasionally forget this step, particularly when making what initially seems like a minor adjustment that evolves into a substantial revision.
Proposed Feature
Add an optional Project Preservation Prompt, configurable under Preferences → Projects.
When enabled, opening an existing Audacity project would present three choices:
  1. Open Read Only — Allow playback, examination, and potentially experimentation without permitting changes to overwrite the original project.
  2. Save as New Project — Prompt for a new filename and create a separate project copy before editing begins.
  3. Edit Original — Open the existing project normally, allowing changes to be saved.
Preferences
  • Disabled by default to preserve existing behavior.
  • Enabled through Preferences → Projects.
  • Optional checkbox: “Don’t ask me again.”
Important Distinction: Prevention vs. Backup
This is not a request for another backup feature. It is a request for a workflow safeguard that helps prevent accidental overwriting of an original project in the first place.
Backups and file versioning are essential, but they address the consequences of mistakes rather than preventing them.
A user may have excellent backup practices yet inadvertently overwrite an original recording and not discover the mistake until weeks or months later.
By that time, the desired earlier version may no longer be available in the backup history.
An optional prompt when opening an existing project would encourage users to make a conscious decision about whether they intend to preserve or modify the original.
Importantly, this safeguard would operate independently of external backup software and would not require users to adopt complicated file-management procedures.
Benefits
  • Helps prevent accidental overwriting of historically valuable recordings.
  • Encourages sensible project version management.
  • Particularly useful for musicians who frequently revisit older recordings.
  • Reduces dependence on remembering to use Save Project As.
  • Requires no changes to existing workflows for users who disable the feature.
  • Complements existing backup strategies without duplicating their functionality.
Summary
For musicians maintaining decades of recordings, the distinction between opening a project to review it and opening it to create a new version can be critically important.
An optional Project Preservation Prompt would provide a simple opportunity to make that distinction before editing begins.
The objective is not to protect users from losing their backups, but to help prevent them from unintentionally changing the very originals they intended to preserve.
In my eyes, this is absolutely unnecessary. If you do serious work (with Audacity or with any other application), you have at least one - or preferrably more - backup(s) available to which you can revert should you accidentally overwrite a file.
Unfortunately not all users have climbed the learning curve to become a user performing “serious work”. So yes, it may seem useless to you. However, newer users at the bottom of the learning curve often overwrite and save stuff, often losing original tracks/projects. The suggestion is to add a safeguard (that can be disabled by POWER users) to guide newer users and remind them they could lose data by SAVING this edit. This is quite important in EDITING software vs DAWS mostly designed for recording, not editing.
This still is a mighty tower of assumptions:
  1. Users open old projects periodically
  2. When they do, they forget it’s old work they’re looking at
  3. When they do, they start editing and saving their work
  4. When they do, they notice their mistake and look for a way to prevent it in the future
  5. When they do, they turn to the preferences to find such an option.
I don’t see any user actually meeting all of these assumptions. Checking the preferences in search of an option already is quite far along the learning curve, a novice user would never even consider such a feature to exist. I find it much more likely for users to:
  • Store their projects in a more convenient format than a project file (eg WAV or MP3) and revisit those from time to time in a player, rather than an editor
  • Store their projects in a location that’s effectively read-only for Audacity anyway (CDs, DVDs, cloud storage)
  • Mark their archive as read-only in the file system (which Audacity currently can’t open, and would force a copy to be made anyway)
  • Open a project in a new version that forces a version upgrade (and thus new file) anyway (aup → aup3 or aup3 → aup4)
Many of your assumptions are assumptions!
  1. Doesn’t need to be an old project for a newbie to overwrite data. Could be their first project.
  2. See #1
  3. See #1
  4. Yes, if the default is hidden away. My suggestion is to enable it automatically upon INSTALL, and let the user keep it or switch it off. See below.
  5. See #4.
Many complicated software programs INSTALL with defaults for beginners. They include bubbles and windows to prompt the new user along. These can be switched OFF by advanced users. Only needs to be done once, unless you install a completely new version or on another platform. These software programs help the newbie along to avoid pitfalls and not discourage the new user off the bat. This isn’t something power users will see more than once, before they switch it off.
Audacity typically assumes you know how to use it when installed fresh. That is the assumption I am talking about. First INSTALL could simply ask, “Are you a new user or are you already familiar with AUDACITY?”. That can set the switch to beginner mode or experienced mode.
I have been turned off by most DAWs because they expect you to already know what there is to know about DAWs. But being a more targeted EDITING platform, Audacity may ultimately be useful to a wider audience.
All I am suggesting is some simpler hand-holding initially to keep new users engaged and not turn them off by allowing them to overwrite their work by simply hitting SAVE. They have not developed ANY workflow habits yet. Why not guide them along until they learn the SAFE workflow and consequently feel comfortable enough to remove the training wheels? This suggestion is not targeted to experienced users. It is a suggestion for developers/engineers to consider - perhaps for future iterations of AUD 4.0. Keep new users engaged so they don’t run back to Garage Band or another APP. Being FREE and having a long history is a selling point for someone trying to figure out how to do BASIC recording/editing.
So Ultimately it is up to developers and engineers to determine if this is a direction they want to go or not. It isn’t meant as an “improvement” for existing, experienced users.
ah, on-by-default then! That wasn’t what you initially suggested.
Again, this isn’t what you initially suggested:
If you have historically valuable recordings or frequently revisit older recordings, you’re almost certainly not a beginner.
Anyway, splitting things up into easy and advanced is a classic design trap :slight_smile: Following it leads to a beginner mode in which users are prevented from doing what they want to do by constant interruptions or simply missing “advanced” features, and an advanced mode that’s too distinct from the simple mode for any of the learnings from that mode to be ported over. That’s why Workspaces were the furthest we have gone for that idea for Audacity 4, and I still think that we have too heavy onboarding with 3 different questions for “do you want new or old” (theme, clip color, workspace).
I suppose my main problem with this proposal is the extra dialog: Counter-intuitively perhaps, your suggestion would steepen the learning curve. Because we’d be showing additional dialogs on opening a projects, users would need to make a cognitive decision every time: Do I want to “open read only”, “save as new project” or “edit original”? “Read only” also is somewhat problematic here because reading is more of a word thing (which then got grafted onto computer jargon), shouldn’t it be “listen only”? if I save as a new project every time “just in case”, won’t I run out of storage eventually? and “edit original”, do I edit the original file (maybe an MP3 I imported), or a project?
When not showing the dialog, a user doesn’t need to learn the difference between these concepts the very first time they open a project. Sure, they may make a mistake (I remember when I did as a kid, it was in a Sims game IIRC where I wanted to load a previous save after messing something up and used the “save as” button instead – and interpreted the “this file will be overwritten” warning as a “you haven’t saved your current game”, which I didn’t want to do), but it’s fine to make mistakes especially as a beginner of the software.
The big thing about what makes mistakes punishing is whether or not the mistake is undoable. And this is where backups come in, where audio.com’s cloud sync with versioning comes in, and where Audacity’s more recent non-destructive editing features come in.
Also, a thought: Perhaps adding aup3 support to something like VLC would be what you really want, so you can review all your old files in a separate program that doesn’t have any editing capability to get in your way.
Well, I submitted the idea. If developers want to take it further, they can. If not, I am OK with that. I think I stated my case clearly at the top. If that isn’t a direction they want to pursue, I am not going to continue arguing the case.
