I am trying to add an effect plugin to Audacity, I have already downloaded the effect and pasted it into the Local Disk(C)/Program Files(86)/Audacity/Plug-ins folder.
When I then look to add it via the effects drop down, the option to add / remove effects does not show.
I’m using Windows 11 and Audacity 3.3.3
I’ve attached a screen shot below, any suggestions?
“86” means you have a 32-bit version of Audacity.
If the plugin is 64-bit , (all new ones are), it won’t work in 32-bit Audacity.
The plugin may work in 64-bit Audacity.
Hi thanks for your prompt reply, the problem I have is activating the add / remove option, it doesn’t appear in the drop down menu so I’m unable to add any plugins be it 32-bit or 64-bit. Any suggestions as to how I might be able to see this option in order that I can attempt to add additional plugins?
The problem is that I can’t install any plugins as the menu drop down to select add / remove plugin does not appear. This is what I’m trying to resolve.
Hi Trebor, thanks for your reply. My instinct is that I only have the one version installed ‘Audacity 3’, can you suggest how I could confirm this one way or the other.
If you rename* the Audacity folder in AppData to, say, “audacity-old”, then restart Audacity 3, a fresh version will be created free from any corruption.
C:\Users\<YouNameHere>\AppData\Roaming\audacity
[ * rename rather than delete then you have the option of going back, and it has useful plugin data ].
