Add more than one track at a time
It would be so helpful to be able to add multiple tracks at once.
Can select a group of files and drag’n’drop them into Audacity in one go.
Yes, for importing files. But that’s not what I need when I’m editing a long track that needs to be separated into multiple tracks.
“split new” creates a copy of the selected audio on a new track, and deletes (silences) the original selection.
https://manual.audacityteam.org/man/edit_menu_clip_boundaries.html#split_new
This is fixed in audacity 4
Excellent thank you for letting me know.
