Right… Unless your laptop has “line-in”, the laptop is the weak link. The mic input on a soundcard or laptop is useless for high-quality recording. Besides typically being noisy, it’s high impedance unbalanced, which is simply the wrong interface for a good performance or studio microphone which has a balanced low-impedance connection (XLR connector).
Otherwise, my biggest concerns would be: Room acoustics, microphone placement, and microphone quality. And of course, instrument quality and performance quality.
It’s a good idea to experiment with mic placement to get a good balance between direct-sound and “room-sound”. Typically, the mic “likes” to be closer to the instument/speaker than you would be as a live-listener… When we listen, we like lots of room sound, but we usually don’t like that much room sound on the recording itself…
a microphone (unidirectional, 600 ohms)…
an amplifier…
How is this all connected? Does the mic plug into the amp, or do you have speakers connected to the amp with the mic picking-up the sound from the speakers?
We might need to talk about your equipment & setup… Especially if there is nowhere to plug-in your mic.
I assume your mic has an XLR connector?
I would like to use the amplifier and the program to enhance the sould, and make it sound “fuller” and “warmer”.
That’s fine, but let me make a suggestion - Get some adapters so that you can record the direct instrument-output on the left channel, and the amp-output on the right channel. If you record both signals, you will have a choice and you can even mix them if you wish. (The “modern way” is to do all of your EQ, reverb, and other effects with software in post-production.) I don’t know what’s “standard” for keyboards, but it’s very common to record electric guitar both direct and with a mic… Sometimes, they might use 3 tracks - Mic, pure-direct, and direct from the pedals.
