3.6.1 running in Windows 11.
Is anyone else having issues with the area sensitivity of the volume and pan adjustments to the left of a recorded track?
When I’m recording a project with 2-3 vocal tracks, plus the backing and harmony tracks, the tracks get quite narrow and those controls get hidden. If I’m editing a track and want to switch to another, clicking in that area to select it almost always changes one or the other, usually volume. I don’t realise that until I play it and get my ears blown off. It’s tedious to have to constantly change the width of the track each time to make sure they haven’t changed.
I wish they would put back the select button, disable those slides if they are not visible, or at least reduce the sensitivity so I have to select the control precisiely adjust it.
Any other ideas?
Thanks folks.
