Hi, I just watched How We’re Redesigning Audacity For The Future dev vlog by Tantacrul, and one thing stuck out to me as a possible major accessibility issue for my workflow in the future release. I have cerebral palsy and have limited use of my right hand. I produce and edit a podcast, and the sync-lock is my most used feature. Keeping mine and my co-host’s audio tracks synced at all time was a great and fast editing future. I just had to highlight a section and press delete to make a complete edit. But if the sync lock is changed to a ripple delete across tracks by pressing shift+delete, I will not be able to press that combination of buttons. I hope that there will be option to keep ripple delete turned on at all times so I can just press delete, making editing much easier
Pretty much every function in Audacity has a keyboard shortcut key that you can change to any combination you want, and I doubt they will do away with that ability.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
