Windows 8.1; Audacity 2.1.1 from .exe
I understand you can’t export some multichannel AAC files unless exporting via an “external program”. I tried following the steps that I found elsewhere in this forum using the command:
ffmpeg -i - -strict experimental -c:a aac -q:a 10 “%f”
But it pops up with an error box. I am trying to output 8 channels. Is this not possible? Or am I missing something?
Here is the error message
ffmpeg -i - -strict experimental -c:a aac -q:a 10 “C:\Video\file”
ffmpeg version 2.2.2 Copyright (c) 2000-2014 the FFmpeg developers
built on May 22 2014 19:56:44 with gcc 4.8.2 (GCC)
configuration: --disable-static --enable-shared --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-decklink --enable-zlib
libavutil 52. 66.100 / 52. 66.100
libavcodec 55. 52.102 / 55. 52.102
libavformat 55. 33.100 / 55. 33.100
libavdevice 55. 10.100 / 55. 10.100
libavfilter 4. 2.100 / 4. 2.100
libswscale 2. 5.102 / 2. 5.102
libswresample 0. 18.100 / 0. 18.100
libpostproc 52. 3.100 / 52. 3.100
Guessed Channel Layout for Input Stream #0.0 : 7.1
Input #0, wav, from ‘pipe:’:
Duration: N/A, bitrate: 6144 kb/s
Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, 7.1, s16, 6144 kb/s
[NULL @ 01cf40e0] Unable to find a suitable output format for ‘C:\Video\file’
C:\Video\file: Invalid argument
Conversion failed!
