A program to extract signals treated as noise could be helpful
Automated separation of Noise bytes helps in application of the Noise Reduction tool. The isolated noise track separately in a project helps in FFT Noise frequencies and in eliminating them. I have been doing this for the last 2-3 years already. But only of late I thought that the code could help my fellow members.
The Noise Threshold could be pre-determined.
I may be directed to a Nyquist code that leads me to accomplish the same in a separate track within a project. Presently, I could do it with Python, but I lack the skill to write it in Nyquist code.
Mr. Steve Daulton could definitely help me in this regard.
The codeline is attached. The execution would be python ExtractSilence.py.
The file should be renamed with an extension .py instead of .txt, and python executables need to be in the system.
ExtractSilence.txt
